Floodier bulbs for first story eve mounted flood light?
willrx
Woodstock , Ga
Is there a bulb that offers even more flood than a standard halogen flood light? The application is an exterior first story eve. Seems like the light is a little too focused. Would reducing the wattage help? Thanks. The other lights that are mounted higher are fine.
I don't really know if there is a halogen to do what you want or not, but I have a fluorescent 65 watt flood I put up and it casts some serious light. It is a round fixture, not one of the one's with the reflector behind it, found it at Lowes.
Here is a fixture and bulb with a reflector, so I don't know if it will be as wide enough area for you (mine casts light 360 degrees) but I am betting it would be.
http://www.amazon.com/dp/B000BO6G94/?tag=cpf0b6-20
Keep in mind you can't just screw this bulb in your existing outlet like a CFL, it needs an external ballast.
EDIT: here is the one I got, I found them on closeout.
http://www.amazon.com/dp/B001BQ204Q/?tag=cpf0b6-20
