Hello everyone,
recently i was trying to wake my 'storage box queens' (4 NiMH GP 2700 mah, non-lsd) which had been into storage for about 9 months without a recharge. when i first started with 0.5C charge followed by a 0.2C discharge on my C9000 the results were quite bad-
Cell 1- 800mah
Cell 2- 180mah
Cell 3- 230mah
Cell 4- 1100mah
also the voltage of the 2nd cell showed as 0.23v :( i was quite worried so i decided to recover them using the method told in this thread. as it was a 'stubborn case' i initially went on with some fast charge and slow discharge cycles(2 cycles) and then lastly discharged them 3 times at 0.1amps to deal with crystalline formations.
after each cycle the cells improved greatly! after gradual improvement, all of them reached at about 1850mah :) and i have yet to do a Break-In on them, then i suppose they would touch 2000 mah which would be 'new like' performance as described in the above article.
now my question is that while performing fast charging and slow discharging i saw that almost all cells at some point of time showed fluctuations while discharging. like one cell behaved like this --> 1.04v, 1.03v,1.04v and so on. the other behaved similarly --> 0.96v, 0.97v, 0.96v and so on. i would like to know what actually is happening here. has it something to do with the breaking of crystalline formations?
also i was trying to diagnose the problem so that i can follow the correct procedure for its recovery. as i am new to battery charging and all, so kindly let me know whether the above behavior shows the normal 'voltage depression' problem witnessed after long storage of NiMHs or is it something else?
Cell 1- 800mah
Cell 2- 180mah
Cell 3- 230mah
Cell 4- 1100mah
