Foam question
turkdc
Shelby Township, Michigan, USA
Does anyone know of a place that sells "pick and pluck" foam to line a case with. I have looked at the local craft stores and have had little luck. The online searches I have done only seem to yield REALLY expensive results.
What is "pick and pluck foam?
Pick and pluck foam is the foam that is cut so you can pull out squares and make a case fit the tools you are putting into it.
I have looked at the pelican case foam and can't quite figure out what the sizes are. I was hoping to find something more generic (and less costly).
