Fooled Energizer 15 minute charger to work with high R cells (with pics)
MrAl
New Jersey
Hello,
Note the pics were introduced in post #10 of this thread, and here
is the link:
http://mral.peu.net/index.php?page=EnergizerChargerMod
The Energizer 15 minute charger has been successfully fooled
into thinking it was charging two AAA cells when really it was
charging two AA cells. This trick allows AA cells with higher than
usual internal resistance to be accepted by the charger and
charged effectively because AAA cells normally have higher
internal resistance anyway.
Here's the story...........
The Energizer 15 minute charger has a slight problem
where if an AA NiMH cell has a somewhat higher than
usual internal resistance the charger rejects it and
does not attempt to charge it at all. Apparently the
philosophy adapted by Energizer is that if the internal
resistance is beyond a certain limit there will be too
much power heating in the cell and could cause a melt
down of the cell and/or charger.
Measuring the approximate internal resistance of several
cells that work and several that dont work in this charger
i have determined that the threshold is approximately
0.100 ohms. That is, a cell that had an internal resistance
less than 0.100 ohms will be accepted in the charger and
will be charged in about 15 minutes, while a cell that has
anything over 0.100 ohms will be rejected and will not be
charged at all (note the 0.100 ohms is approximate).
Calculating the power for each cells internal resistance
at 10 amps charge current and 0.100 ohms Ri leads to
10 squared times 0.1 which equals 10 watts. Since the AA
cell has a surface area of about 3 square inches, the
temperature rise due to the internal resistance alone would
be enormus, should the cell be left to run in this condition for
an hour or so. The plastic of the charger would eventually
melt. Of course with half the resistance we get half the
power heating and this too would get hot if left long enough.
Luckily, it's only allowed to run for 15 or 20 minutes, and
there is a fan to help cool the cells down.
In any case the main issue here is that once the cell reaches
a point where it's internal resistance prevents it from being
charged in the Energizer charger we have to look for another
way to charge this cell. I had four RS cells, two of which
would not charge in this charger and now just recently one
other cell (now a total of three) wont charge in it either.
Interestingly, since the Energizer charger also charges AAA
cells and AAA cells have inherently higher internal resistance
we could fool the charger into thinking it was charging AAA
cells when really it was charging AA cells if there was a way
to stop it from sensing the longer AA cell once it was inserted
into the charger. Since it accepts the higher resistance of
the AAA cell it should accept the higher resistance of the AA
cell once it's fooled. The drawback is that when it senses
an AAA cell it also cuts back the current to one-half the normal
AA cell charging current, so it's going to take twice as long
to charge an AA cell. The good news is at least it will charge
it, and also 30 minutes isnt too bad either.
Ok, so the only thing left to do is find out how to fool the
charger into thinking it has an AAA cell in it rather than
an AA cell. Lucky for us, the charger has a switch mechanism
inside (one for each cell position) that closes when a cell
that is longer than an AAA cell is inserted into it. The switch
closing tells the charger to charge at a high current and also
to look for low internal resistance and reject any cells with
an internal resistance that is too high. Peventing this switch
from closing means the charger thinks it's got an AAA cell in it
(the terminal contacts do not change) and it starts detecting
the internal resistance that would be typical for an AAA cell
and switches the current to about half max output.
The only problem then is getting to these switches. They are
all inside and not accessable from the outside of the case.
This means the case has to be opened up, and the circuit board
removed. The four switches become clearly visible as they are
each about 1 inch long and look more like relay contacts.
The only thing necessary to do at this point is to slide a thin
card (like an index card) under the switch contacts so that
they can not close, even when an AA cell is inserted.
The drawback here is that a slot would have to be cut in the
side of the charger case to allow sliding the card under the
switch contacts when we want to charge AA cells using the AAA
cell charge algorithm (ie fool the charger).
Alternatives to using the card trick:
1. Remove the switch contacts completely and mount four SPST
switches on the case and manually switch between AA and AAA cells.
2. Solder a new four position
AA cell holder externally. Note there are no common terminals
for any of the cells, so this means 8 wires would have to be run
from the AA cell holder to the charger circuit board.
3. Plug 'dummy' AAA cells into the charger and have their terminals
connected to a four cell AA holder. Each cell *MUST* be wired
independently however, so this requires a minimum of 8 wires. The
wires should be very short and heavy gauge too. The wires internal
to the charger look like #12 flat. The idea is to keep lead
resistance to a minimum, or else the charger will still reject
the cells. The nice thing about this idea is that it does not
require modification to the charger itself.
Actual Test
An actual test was done to see just how good the card trick
would work out. The case was taken apart via three small
screws and the circuit boards removed (connecting wires folded a little).
After the circuit boards are removed the wires are still attached
and the unit still operates, the only difference is the switches
can not be activated via a cell insertion, so the charger always
thinks it's charging AAA cells. This turned out to be the best
way to test this, so leaving the two circuit boards out of the
case (and inserting another insulating card between circuit boards
to prevent shorting) and inserting two AA cells the unit was ready
for the test.
After plugging the unit in, the LED lit red and stayed red!
This was a first for these two cells. This meant they were
actually charging in this charger when before they would not.
As noted previously, i expected a longer charge time, and that's
exactly what i got. After 20 minutes the charger LED turned
green, indicating that the cells where charged. I suspected that
this was not long enough, so i unplugged the charger and plugged
it back in after about five seconds. The LED turned red, and
the cells were being charged a second time. I expected to see
another 10 minutes charge time, but it actually took closer
to about 20 more minutes, after which the charger LED turned
green again. To make sure they were really charged this time,
i unplugged the charger again and waited another five seconds,
then plugged back in. Within about 30 seconds the LED turned
green, indicating that the cells were really charged this time.
I would guess that the charge algorithm has a cut off time
period of 20 minutes, even if they are not done. Unplugging
and plugging back in allows them to get the needed charge time.
It took a little longer than expected (40 minutes vs 30) but
hey at least they charged this time!
The heat output of the cells during charging was minimal, maybe
warm, but no where near hot, and this was also expected because
the AA cells have about 50 percent more surface area than the
AAA cells have, and this keeps them cooler than AAA cells would
be powered by the same charge current.
I will probably go with the card trick, and slot in the side
of the case for a long term solution. I like this better than
having to solder to the circuit board or trying to provide
a second four cell AA holder. I also cant see mounting four
switches on the case, even small ones.
If anyone is interested i'll try to get some pics of the dissassembly and
where the card is to be placed to prevent switch closures.
Re: Fooled Energizer 15 minute charger!
The AAA/AA selection is determined by the lenght of the cell on the E-15 charger.
EDIT:
Whoops, didn't read the whole post!! You can trigger the switch with two metal pieces with a insulator between them of the proper lenght and clipped to a external clamp. I used this method to test the E15.
Hi Bill,
Im not sure you understand...the idea is to *NOT* trigger the switch.
If the switch is not closed, the device goes into AAA mode which means
it thinks higher resistance is ok and will charge the cells even with
higher resistance.
Al:
Okay, your keeping the higher amperage rate of AA mode, gotcha!!
EDIT:
Nope, your charging at the AAA rate! If you installed as I suggest, a two piece metal with insulator to simulate a AAA inserted, clipped to a clamped AA cell, the E15 thinks that it's a AAA cell. What's the diference?
When I first used this setup on a E15, I was only getting 3.5A and it was because my spacing was too short.
Interesting post. I was thinking about doing something similar for the same reason (never got past the thinking stage though :))- would be interested in photos if possible.
Hi again,
Bill, yes if you use your device it should also work to fool the charger
but you'll have to keep the leads short. You do in fact want to keep
the 'insert' short, not too long, because if it is too long it will trigger
the switch and the charger will again reject the cells.
Photon:
This charger is pretty interesting in itself. While i had the case open
i took a moderate look at all the tons of parts inside. i think there was
one 14 pin ic and another ic with lots and lots of pins (24 maybe),
all surface mount. Tons of SM resistors too, and an ample amount of
small SM caps too. The cell multiplexer included 8 (yeah, count 'em, eight!)
MOSFETS, all SM with 8 leads each. These MOSFETS allow the charger to
get by on one (yeah count it, one!) switching regulator as suspected.
The toroid is a nice size one too wound using simulated Litz wire (ie multiple
strands of insulated wire to make up one large gauge wire of maybe 12 gauge).
Two additional TO220 MOSFETS (TO220 package) drive the switcher.
The switcher has it's own circuit board, with the actual charge controller
and cell multiplexer on another board. Overall this charger is no simple device.
I'll try to get some pics up tomorrow some time, as this would really illustrate
the complexity of this charger and show how interesting it really is, as well as
help others to identify the switches and how to get to them. It's not that
hard really, but if anyone attempts to take theirs apart i would suggest
watching out for the small black spacers that pop out once the case is
pulled apart. These things keep the two circuit boards spread apart so
they dont short out. In case they drop out, one spacer per "black post",
where the 'black posts' are the small plastic posts where the screws go
into when the unit is assembled. It's a little tricky getting them back in
(i used long nose pliers) but if they fall out and you havent seen where
they go it might not seem too evident where they go when you go to
put it back together again. It takes a little finesse as one side has a
heavy ribbon cable connected to it, which prevents the top board from
being moved up far enough to get the spacer back in, although with a little
jiggle it does in fact 'just' slide back into place.
I've had a little time to think about it now, and i think i am still going with
the 'slot in the side' solution, as this would be fairly easy to do with a
dremel and an index card cut to about 1/2 inch wide will easily stop the
switches from making contact so the unit stays in AAA mode.
BTW, anything thicker than an index card should not be used as it may
cause the switch contacts to bend permanantly so the unit may not properly
go back into 'normal' AA mode when you want to do 'normal' low resistance
AA cells again (in 15 minutes).
Hi again,
There doesnt seem to be too much interest in modifying this charger i guess.
For me it will mean charging my older AA cells much faster than using the
older 4 hour charger, so i think it's still worth doing.
Hello Al,
First of all, let me say that I am not interested, at all, in prolonging the life of :devil: "crap" :devil: cells... :)
However, charging at 3 amps is just over 1C for some of the higher capacity cells, and that is very attractive. There are very few consumer chargers that are capable of charging these cells close to 1C. On top of that, we also have forced cooling.
I will have to open mine up and have a peak inside...
Tom
Hi again,
Tom, yes there are various reasons for wanting to do this mod. Some of my cells
are still fairly new yet they dont charge in the charger 'normally'. I figured it
wouldnt be too much work to get it to charge them so that's part of why
i wanted to look into this possibility. Since it can be done quite easily (the
card trick) i am going to do it with my charger very soon. I'll take some pics
and post here.
BTW the Duracell charger looks like it would be harder to mod because it
has separate contacts for AA and AAA cells. This would required breaking the
AA connection and connecting it to the AAA terminal so the AA gets the current
intended for the AAA. Alternaltely an external four AA cell holder (with independent
bays) could be wired in, but i dont see any "card trick" possible for this charger
as there is for the Energizer charger.
Energizer 15 minute charger Modified to charge high resistance AA cells (w/pics)
Hello there,
Here is a picture story to show one simple way to modify the
charger to allow charging AA cells that are normally rejected by the
charger because of higher internal resistance.
The actual modification shown in the pics converts two of the four
cell bays into slower charging bays, and leaves the other two alone,
however any number of bays can be converted by simply getting
the index card under the respective switch contact.
This has been tested and has been shown to work very well, although
some cells have to be charged 'twice' by unplugging and plugging the
unit back in again to allow the cell to get fully charged. Takes up to
40 minutes total (20 minutes each cycle). The unmodified bays still
allow charging in 15 minutes for cells that are accepted by the charger.
Hello Al,
I believe the charging currents on the Duracell 15 minute charger are a little higher than the Energizer charger. However, I am not sure if the timer runs longer, or what value for internal resistance they use as a cut off.
Tom
Re: Energizer 15 minute charger Modified to charge high resistance AA cells (w/pics)
Hi Tom,
Well, the Duracell charger rejected the same two cells that the Energizer
rejected, and accepted the other two, so i assume the cutoff internal R
is roughly the same for both chargers. It looks like about 0.100 ohms or so.
Hi again,
Originally the test was with a 1/2 inch wide strip of an index card
that was placed under two of the four contacts, but since i couldnt
get the card out easy and once out it would not be possible to put it
back in without taking the whole thing apart again, i decided to put a
slot in the side of the charger so that the index card could be inserted
in when the cell(s) require lower current charging, or it could be pulled
out when full current charging is desired.
The slot only needs to be about 1/16 inch high and about 1/2 inch wide,
right above the circuit board that holds the switch contacts and on the
side of the unit so that when you stick the card in it slides under one to
four switch contacts, allowing from one to all four bays to be used for
lower current charging and the remaining bays still on high charge.
