Don't fall victim to the 'Free Wi-Fi' scam
Those wireless connections could be a trap
The next time you're at an airport looking for a wireless hot spot, and you see one called "Free Wi-Fi" or a similar name, beware -- you may end up being victimized by the latest hot-spot scam hitting airports across the country.
You could end up being the target of a "man in the middle" attack, in which a hacker is able to steal the information you send over the Internet, including usernames and passwords. And you could also have your files and identity stolen, end up with a spyware-infested PC and have your PC turned into a spam-spewing zombie. The attack could even leave your laptop open to hackers every time you turn it on, by allowing anyone to connect to it without your knowledge.
If you're a Windows Vista user, you're especially susceptible to this attack because of the difficulty in identifying it when using Vista. In this article, you'll learn how the attack works and how to keep yourself safe from it if you use Windows XP or Vista.
How the attack works
First, let's take a look at how the attack works. You go to an airport or other hot spot and fire up your PC, hoping to find a free hot spot. You see one that calls itself "Free Wi-Fi" or a similar name. You connect. Bingo -- you've been had!
The problem is that it's not really a hot spot. Instead, it's an ad hoc, peer-to-peer network, possibly set up as a trap by someone with a laptop nearby. You can use the Internet, because the attacker has set up his PC to let you browse the Internet via his connection. But because you're using his connection, all your traffic goes through his PC, so he can see everything you do online, including all the usernames and passwords you enter for financial and other Web sites.
http://www.computerworld.com/action...ewArticleBasic&articleId=9008399&pageNumber=1
