Not FS: *300mW MXDL Open Can Lasers With Heatsink*
No longer selling these... Please read this:
http://www.laserpointerforums.com/forums/YaBB.pl?num=1231511226/0
But I am selling DIY Build Kits & Heatsinks! See here: http://www.sonic.net/~jayrob/MXDL/
My 4171 build, is just a 'pumped up' version of Daedal's original 'DIY Laser Torch'.
The differences are noted at the end of this first post.
* Yes, one of the build options here, is a 300mW MXDL (for this, I recommend the FlexDrive option set at 430mA's using the Meredith glass lens)
--Either build is very clean. Built with my custom fit heatsink, 420mA's DDL style driver (or FlexDrive option), long open can diode, running around 250mW's to 300mW's (depending on lens choice)--
'Long' open can diodes harvested from Pioneer 115D DVD drives, or LG LPC815 sleds (same difference). These can be mounted into the module of your choice. The acrylic lens is better for burning. (because you can focus it tighter) The Meredith glass lens gives more power, and is also $10 bucks more than the Meredith acrylic.
I like 430mA's these days. This will give you about 250mW's with an AixiZ acrylic, or around 300mW's with a Meredith glass lens. (heatsinked) I think that 470mA's is really pushing these diodes a little too much. Even with the thick heatsink.
The FlexDrive driver with the 4171 host, needs a silicon diode installed to drop the supply voltage to 5.5 volts. (This is the max input voltage for the FlexDrives)
Also, with the use of these FlexDrives, this host is now an excellent blu-ray host as well! Using the 3.0 volt Lithium batteries.
More details:
A Meredith glass lens will give a higher power reading, but will not allow you to focus the dot as 'tight' as the acrylic. At that power, yes the Meredith glass lens will easily light matches at 10 feet. But an acrylic lens will burn even better. Here is a picture and a video on this page. The picture shows two lasers with the exact same current.
http://www.laserpointerforums.com/forums/YaBB.pl?num=1199846835/75#77
I have them labeled. The glass lens laser is putting out more power because of the glass lens. But the video of the match burn at 4' distance, is with the acrylic lens laser. An MXDL acrylic lens laser at this power, when focussed properly, will light a black tipped match, at 20'! Pop black balloons at 30'. The 'finger grip' ring turns for focussing. The difference between focus at 5' vs focus at 20', is only about 1/32 of a turn. For an example about focussing, I have two dots marked in this picture: (with a little dot of white paint)
One mark is for 5' focus, and the other is for 100' focus.
My 4171 build, is just an 'upgrade' of Daedal's original build.
The differences are:
* The open can diode
* The heatsink
* The use of the 3 ohm resistor, instead of 2 x 10 ohm resistors and a pot. No pot, and just the 3 ohm resistor at the LM317 will give you the 420mA's. (about 250mW's with an acrylic lens – 300mW's with a Meredith glass lens)
* Heatsink needed! As well as the 3.6 volt batteries. His laser thread doesn't mention the silicon diode and cap, because he covered that in his driver thread. He shows pictures of those components in his build.
New: I have a Version 2 heatsink design for the sku's 4171 and 3405 hosts. Now you have another choice!
These two hosts have a massive heatsink and this new design still has plenty of mass...
These two hosts have enough room inside that we can have a heatsink that is 'flat'. Not protruding out the front.
Still will fit either module. Here's how the finished build will look with the version 2 heatsink:
So now you have more choices!
Just let me know which host for you build, heatsink style, module, diode, etc... (same price)
Daedal has a very good guide on the building of this MXDL host here:
http://www.laserpointerforums.com/forums/YaBB.pl?num=1186966870
DDL's driver thread is here: http://www.laserpointerforums.com/forums/YaBB.pl?num=1185701612
I have a couple of documents and 'tips' on doing this build using my custom heatsink. In my 'Driver Tips' document, you will find a good schematic of the original DDL driver.
http://www.sonic.net/~jayrob/MXDLDriverTips.doc
http://www.sonic.net/~jayrob/MXDLHeatsinkTips.doc
Jay
More details:
* The heatsink
Jay
