jimjones3630
I consider all of these batteries used taken apart from packs, discharged at .2A and charged to capacity. All within 10% capacity.
A123
http://candlepowerforums.com/vb/showpost.php?p=2120470&postcount=1
http://www.aircraft-world.com/prod_datasheets/hp/A123/A123.pdf
http://www.a123systems.com/newsite/pdf/ANR26650M1_Datasheet_FEB2007-1.pdf
http://candlepowerforums.com/vb/showthread.php?t=160048&highlight=5761
http://a123racing.com/html/rcdevkits.html
Emoli
IMR26700A Lithium Ion Batteries
Unlike Lithium Polymer batteries, these cells are very rugged. It is encased in a steel can similar to NiCAD/NiMH batteries.
Specs:
Dimension: 26mm diameter x 70mm length
Weight: Approximately 100g
Mfg Claimed Capacity: 2900mah
Nominal Voltage: 3.7 V
Charge Voltage: 4.2 V
Mfg's Max Continuous Discharge Rate: 20A
Max Tested Continuous Discharge Rate* : 45A (15C)
* Not endorsed by Manufacturer.
By eliminating cobalt from the IMR26700 cell it is possible to produce a much larger cell, while providing exceptional safety characteristics. Further developments of the IMR26700 cell will provide fast charge capability, allowing cells to be fully charged in as little as 15 minutes.
Cell Type IMR26700 Manganese
Size 26.4mm diameter; 70mm length
Weight 100g
Capacity 3Ah
Standard Operating Voltage 4.2V - 2.5V
Energy Density 285Wh/l
Power Density 1500W/kg at 20 seconds
http://www.swift-tuning.com/EMOLI_26700A.pdf
A123
- Nominal capacity: 2.3Ah
- Core cell weight: 70 grams
- Internal impedance: (1kHz AC) 8 mΩ typical
- Typical fast charge current: 10A to 3.6V CCCV
- 70A continuous discharge
- 120A, 10 sec pulse discharge
- Cycle life at 10C discharge, 100% DOD: over 1,000 cycles
- Power: Over 3000 W/kg and 5800 W/L
- Safety: Inherently safer and environmentally friendly
- Life: Superior calendar life, 10X cycle life vs. conventional Lithium ion
- A123 cells are POSITIVE ground casings. Uses a nanophosphate positive electrode (cathode).
- Long running constant out put, one of the flattest discharge curves of any batteries. Cells are rated 70Amp or 30C discharge continuous operation. (33C pulsed)
- Typical RC chargers rated for A123 recharging: BC-6
Emoli
Specs:
Weight 100g
Capacity 3Ah
A123 5 available $19.95 each new, now $15
Emoli 4 available $17each new, now $12
shipping extra, paypal add 4%.
