Re: FS: Dimmable Tri-LuxIII FatMag2C
Icarus, just found another feature. Suppose your on a trip and you forgot/mis-calculated the need for your Pila charger, and you've been showing off the light too much and got caught with your Pila's flat.
And you NEED your fllashlite and your stuck in Way-Out-Back and the only CR123A's are $15+ for a pair from the local photo shop if you can find'em. OK, drop $30 for 4-CR123A, or what.
Well pick up two quailty C-cells and drop them in, you will not get full brightness, but it's still brighter, better quality light than any two cell maglite and the dim function still works!!
So your power options are: Full power 2xPila 150A, 3xCR123A in an emergency 2xC-cells.
This is just one wonderfull flashlight.
=D~~ Kilted
P.S. Do not misplace your adapter and Pila's!!
