ARC mania
I have some parts left over from the Extreme Micro CR2 flashlight run that I made a while back. These parts include the following:
40pcs of the inner modules machined from T6061 material. Includes ground screw and washer.
40pcs of converters which have 3 levels of light plus strobe, beacon and SOS. driver is based on the Linear 3490.
40pcs of the Golden dragon LED with optic. Part# LW_W51M KY in brightness.
I'd like to sell this as one lot in an unassembled state for $850.00 shipped express. This breaks down the cost of each module to $21.25 each. All the parts are brand new. This will enable who ever buys this to make 40pcs of 1 x CR123 flashlights, just have to machine a body around the module. I will also help show how the module is assembled as well. All parts except the LED's were made here in Japan. The beam pattern of the Golden Dragon LED with optic is similar to the beam pattern of the so called 5mm snow LED used by Peak in their lights but since the Golden Dragon LED with optic is a 1 watt LED, its much much brighter. If you have any questions, please ask here or send me a PM. Thank you.
ARC mania
ARC mania
