Drewfus2101
-AA Minimag in silver color, very lightly used with NO major scratches or blemishes on it.
-TerraLUX 5EX Ministar 2 Extreme with SSC P4 LED. INTENSE WHITE BRIGHT LIGHT output comes from the ultra efficient SSC 3 Watt LED which is estimated to output 80-100 lumens. The Seoul SemiConductor (SSC) P4 does not fade when it gets hot, so its light output is stable even after extended run times. The SSC P4 U-Bin LED uses the same die used in the Cree XRE-7090 LED which has revolutionized the LED marketplace.
-Rear clickie. No idea what brand it is. But it works great. Push button is slightly recessed which is nice. Black rubber push button.
I have done the "washer" mod to the light. This involves using a washer between the light and body of the mag to help transfer heat. It also keeps the head from being able to twist and place too much pressure on the light. I have also applied dielectric grease to all connections to help seal out moisture and transfer heat better. Does not come with batteries.
Picts to follow.
$30 shipped.
Picts to follow.
$30 shipped.
