netprince
- Joined
- Sep 7, 2008
- Messages
- 547
I am interested in building a 3xMCE light :twothumbs, and I have two of these, so one has to go :mecry:. Here are the specs and pictures:
Stats:
Standard 2D Mag host
Cree MC-E 5A, wired in serial
Fivemega medium orange peel aluminum reflector, modified for fit
maxflex3 driver, set for 700ma (installed with copper coupler as heatsink)
fivemega 6AA -> 2D battery adapter, filled with eneloops (included)
ultra-clear glass lens
green afterglow installed around emitter
battery stat indicator under rubber button (haven't found clear boot)
estimated lumens: about 600
Pictures:
The light is in very good condition, it has been stored in a pelican style gun case, and only used occasionally. There are a few very light scratches, I tried to photograph the worst one in the last photo above.
beamshots:
I usually de-focus the head just enough to get rid of the MCE donut. The beam does have artifacts while up close, but they are mostly smoothed away after about 15 meters.
UI:
Currently, I have the driver set to no-memory operation, click-on to level 2. To select high, I click the light on, then press to jump to high. To select one of the 5 levels, start with the light off, and press and hold until the light cycles to the desired level. Also, I have the light set to auto-off after 15 minutes without input, and reduce power after the temperature reaches 60c. I can look up the low battery settings if anyone is interested.
I can adjust the UI for you before shipping if you like.
I posted a table of the approximate power settings and runtime here:
http://www.psyc.vt.edu/lenslight/power_settings.html
I am asking $149 shipped conus. First to post 'I'll take it' has priority. Payment accepted via paypal, will PM you my address.
Please feel free to ask questions...
Thanks!
Stats:
Pictures:
beamshots:
UI:
Thanks!
