All sold: -----Solid COPPER MT-G2 Heat Sinks----!! Direct solder bond capable!
Hi all, ALL SOLD THANKS EYE CANDY IN POST 21
I am having a batch of solid copper heat sinks made for use with Cree MT-G2 in a Maglite. These sinks will be machined/milled from solid 1-1/2" Tellurium copper rod.
Here is an aluminum copper hybrid one I had made before. This picture is just for reference, so you can see what it looks like, the batch for sale will be solid copper NO aluminum.
As you can see there is a milled pocket to assist with centering the LED.
The pedistal is .500 tall for a variety of reasons.
1. Most important is that the emitter can be reflow SOLDERED DIRECTLY TO THE SINK and you can still then get you soldering iron under it to solder on the wires.
2. The added height makes it possible to use this with large deep reflectors that have been bored to 16mm like the Fivemega throwmaster and the 3" heads. This will reach the emitter high enough to get full focus.
Here is what it looks like in a thowmaster head.
The only other variance in the sinks from the one in the picture besides being of solid copper and not a hybrid is there will NOT be a set screw in the sink, they be a snug but not tight fit in a mag neck and a dab of epoxy will be needed to secure them.
Using this direct bond system you can easily push the MT-G2 emitter to a full 6000ma with a 6V led. That is DOUBLE what they are rated for. That is the equivalent of FOUR XM-L2 emitters worth of current in ONE SINGLE DIE!!!!!
Literally THOUSANDS of lumens from a single emitter. With this we are nearly creeping up on incan bulb capability.
Prices are as follows.
1pc........$74.50
2pc........$68.40 each
3pc........$64.90 each
5+pc......$52.25 each
NEW PRICE BRACKET ADJUSTMENTS
1pc........$68.50
2pc........$63.32 each
3pc........$55.90 each
5+pc......$49.25 each
Please also MAKE A NOTE IN PAYPAL. Please leave your CPF handle and how many sinks you want. <----- This is important so please don't forget.
ALL SOLD THANKS>
Thanks everyone, and happy modding.
1pc........$74.50
1pc........$68.50
ALL SOLD THANKS>
