Sold/Expired FS: XP-G Extreme III.
ARC mania
The land of the rising sun.
I have up for sale 25pcs of the Extreme III's with the new Cree XP-G R5 in brightness LED's. They are meaner and brighter than ever before. Each light is thoroughly tested and burned in for an hour before shipping. The Extreme III is a very complicated single AAA powered flashlight that requires a lot of patience. Further details of the Extreme III is as follows:
The Extreme III is a single AAA powered custom light utilizing cutting edge technology. The body is machined from T6061 aluminum, type III hard anodized in natural ( no mis-match ) combined with double side AR coated mineral glass lens, Custom orange peel aluminum reflector, hand selected Rebel LED for optimum brightness and, a micro processor controlled DC/DC converter with multi functions all packaed into a very small package.
The Extreme III is user programmable and the ultimate 1 x AAA powered custom light made in limited numbers.
Main features:
Unique 2 stage output twisting mechanism which does not require the user to cycle through all modes.
Turn Off Memory - the Extreme III will turn on in the last operating mode.
Programmble output for the 2 stage output and 2 stage SOS.
Programmable output and frequency for the 2 stage Strobe.
No flickering at ANY output level as the frequency of the PWM is set at 7800Hz.
Over discharge protection for Li-Ion & NIMH battery. (ON / OFF)
Indicates battery voltage level by number of blinks.
White diffuser for area lighting. (lantern head, container of lube and spare o-rings included.)
One word of caution is that the Extreme III will be damaged immediately when a 10440 battery is inserted backwards.
Specifications:
LED : Cree XP-G R5 in brightness, WC in tint.
Input voltage : 0.9V - 5.0V (AAA/10440)
AAA battery chemistry : Alkaline(1.5V), NIMH(1.2V), NICD(1.2), Primary Lithium(1.7V) & rechargeable Li-Ion 10440(4.2V)
Uses PWM at high frequency 7800Hz. No flickering from 0.2% to 100% output
AR Coated glass lens (Diameter 12mm, thickness 1mm)
HA III natural finish, no mis-match.
Single o ring seal at lens, LED module & battery tube.
3 positions twisting action for on/off and programming : off, P1, P2
Tighten for off. Reduce the chances of losing the complete head (bezel & LED module)
Lock out mode : loosen 2 turns
Stable tail stand even with small keyring, similar to the KIB flashlight.
Area lighting with white diffuser installed
water resistant
Size:
Length : 77mm
Diameter : 14mm (bezel)
Main functions:
FOUR (4) operating modes
1. Standard mode - 2 output level. default at 15% brightness & 50% brightness
2. User adjustable mode - default at 50%. Adjustable from 0.2% (8 seconds) to 100% (8 seconds)
3. Strobe mode - 2 stobes level. default 1 Hz at 50% brightness at 15.6 Hz at 100% brightness
4. SOS mode - 2 SOS brightness. default 6.5% & 50%. cycle repeats every 3 seconds
all of the above output and frequencies can be changed by the user via the programming function.
FIVE (5) Extra functions
1. Battery voltage indicator - works on Alkaline, NIMH & Lithium Ion battery
2. Programming function - User can define the output and frequencies of the 4 operating modes mentioned above
3. Demo function - Will display all available brightness and frequencies of the four operating modes. Demo runs for a few minutes and revert back to previous operating mode
4. Overdischarge protection for rechargeable batteries - works on NIMH & Lithium Ion battery (4.2V, 10440)
5. Factory reset - Restore EEPROM back to factory default settings for all operating modes & extra functions
The Extreme III has a unique design in its software code. It will remember the last operating mode when the light is turned off. the next time the user turns on the light, it will turn on in the last operating mode (i.e. previous mode).
for example, if you use your Extreme III mainly as strobe light or SOS, you do not need to go through the process of selecting strobe or SOS again everytime you turn it on.
The price of the Extreme III is $126.00 which includes Paypal fees and shipping via express mail (EMS) to anywhere in the world. The Extreme III is in stock and will ship within two to three days time as I am juggling the SF-III project. I can only accept Paypal for payment. When sending payment, make sure to include your full name, CPF NAME, complete shipping address and what you are paying for. Please send your payment to: arcmania (at) hotmail (dot) com Thank you.
ARC mania
Got mine today. Man, that was fast!! This one is noticeably brighter than my Rebel III. Good job Mike. :thumbsup: If anyone is on the fence, jump off, I'm glad I did. Now, where did I put those rings? :confused:
:devil:
I've got an Extreme III with a Cree XP-C in it. What's nice is that it has a tighter beam than the original Rebel. Comes with a smooth reflector. I only made one of these and would like to ask $105.00 shipped express.
ARC mania
