Samuel Culper
Is there any way to disassemble the switch (shielded) on a Fulton MX-991\U?
I have sprayed Electronics Cleaner into the cracks and crevices as best as I could and that improved my ability to get it to turn On.
With other devices that are not turning on properly or seem to not have full connectivity I have had quite a bit of success in disassembling the switch, plug, or other connecting point, cleaning the metal, wire, or contact points, then applying the thin layer of OxGard grease and reassembling.
The Slide button almost looks the it could be pried apart. Almost! But I am not willing to take that chance on permanently damaging the switch assembly.
Worse Case Scenario; I could try a few more sessions of spraying Electronics Cleaner and see if it will continue to improve connectivity.
Thanks In Advance for any advice or suggestions!
