G2L + Dereelight 2SD Questions
adamlau
Los Angeles
1) It appears as if the P60L module has an additional spring surrounding the smaller contact spring. Is this larger spring to be removed and reused with the 2SD module? 2) How does the hi/lo work with the G2L and the 2SD? I am assuming the light switches on when turning the tailcap and that hi/lo is then controlled by way of momentary clicks. Is this correct? Or does the G2L only work with the 1SD?
adamlau
Los Angeles
To heck with it, I just picked up both the 1S and the 2SD. Interesting in that the outer module spring wire appears to be soldered and sealed to the module itself...
