[size=+1]To make a M*g85, everything you need including 9AA to 3D battery holder, bi pin socket, WA1185 bulb, glass lens and aluminum reflector are available here.[/size]I have two Maglite 3D and would like to customize the Mag's to increase the output of light.
I have seen that you seem to have your act in order and need your help with the parts needed.
Can you help me out?
thank you so much for all that you do
FM, is there enough resistance in a 2D Mag to run an 1185 with your bi-pin socket using 3xIMR26500?
FM, is there enough resistance in a 2D Mag to run an 1185 with your bi-pin socket using 3xIMR26500? In post #1 of your sales thread, what battery configuration did you use to run the 1185 for 50 min?
