Re: Beyond the basics for Li-ion safety?
i had to quit putting them in the garage, when the quantity of solvent, gas, paint, oil, cardboard, wood, and other stuff that would "contribute" if ever an ignition occured, there was some point where the garage was no longer "safer" .
if you have it in a tall open container where it can not "fly out", and a small fire could occur in the container and it would not cause a problem, then it is likly to be very safe.
I guess i would rather see a fire start, then to have it build up before i saw it. but if the fire will be contained, then i dont need to see anything.
odd things to add , often homes do not have smoke alarms in garages, because it can be set off by the car exhaust , here they did not put the smoke alarm in the garage, only the fire sprinklers, and the sprinklers use a different valve releace too, i did not understand. I still have not put a smoke alarm in there, but i got electric doors
where are my priorities :thinking:
Li-ion does not like to be charged in extreeme cold, but i dont know what temp that is , if it is going to be extreemly cold, then you would want to know that spec item.
i have no intention on making that descision for you, you already know enough to be aware. and it doesnt do any good to be terrified, aware and proactive, beats making error out of fear.
Had one battery in pieces in the garage, using gloves and a face mask and doing all the "right things", while i was testing something else, the garage door opened and the other person drive right over the top of my battery. :wave: sooo, you have to decide. to many factors.
