Illum
While we have a proliferation of new threads based on convering existing LED night lights I haven't been able to find one that winds up from incan
I "rescued" this nightlight from a garage sale at no cost after deciding off the bat that it would be a good LED candidate...little did I know its secrets.
The simplist form of an AC driven LED circuit is this
Granted the concept of this was initially designed for 5mm LEDs
D1 was a 5mm white
D2 was used with a 1N4003 diode
R1 was a 100Kohm, 1/2W resistor
If I was to underdrive a CREE at 150-200ma, what resistor value do I need? Or should I do away with this circuit and use something else?
I'm pretty sure the 1N4003 can survive:candle:
the nightlight in question is this [NNL-10, first one top left]
Penny on top
Split
In stock mode it houses two neon lamps each wired to a 3.3K ohm resistor and the output is ridiculously low. Orange at best and consumes about 0.25W each on AC
In addition to the near opaque cover a LuxI driven at 50ma can't even penetrate it [not to mention 5mms]. so I hooked up the power supply and tried 150ma with a CREE XR-E "Q4" and it looked very nice, all yellow and fancy.
The interior space is a decent cylinder 2-3/16" diameter at 3/8" deep, which should be partially filled by a 1/8" heatsink soon
I'm inclined to step down the AC through the use of 1N4004s in the same manner as several dynamo hub lights in the bicycle section, but I'm not sure what to do after that. Plus whatever compensation I have to include for AC drops and peaks:shrug:
Any idea where to start?
D1 was a 5mm white
Penny on top
Split
