Anybody use either 18650, 17670 or 2xRCR123 Li-ions in a Gladius Night-ops? Just need to know if any of these will work well in that light. (Mods feel free to move if this should be in batteries subforum) Thanks yall.
It's the other kind of flash: while the light is on, it'll rapidly blink off-on, off-on (2 "blinks") every 15 seconds or so.Hopefully a very dim flash? (like the locator flash on EDC U60) Any ideas on runtime with 168S or 600S? Thanks again...
That's weird! I have a Seoul'ed Gladius too and I'm getting around 55 mins runtime from 2x 3.0v 600mAh rechargeables. At the end, the light only blinks once, then low voltage protection kicks in and the light goes out.I use generic protected Chinese RCR123's in my Gladius fitted with an SSC. The batteries are rated 3.0v and 1000mAh. I can get to about 36 minutes before the low battery blink starts. It will slowly reduce in output but stays on for well over an hour. Haven't ran it down but I can see it being on for more than 2.. However the output is very low.
I use those sold by AW. Did another runtest today. Light was submerged in water to prevent the light from reducing light output due to heat. Got around 50 mins before blinking.It might be the batteries. I need to get my hands on a "name brand" 3.0v RCR123s to test out.
I'm going to take a stab at some Powerizer or Tenergy 3 volt RCR's pretty soon. Hopefully they'll be better than the generic ones I have. My Gladius is my SHTF in the house go-to light and need it to be 100%.
Good point.In this case, rechargeable cells is not the best option to begin with due to their lower capacity (compared to primaries) and self discharge - especially with protected cells. Especially in Gladius, which drains the cells even when it's off.
Personally, for a SHTF application where the light needs to be 100% when I grab it, I would only use primaries in the Gladius - and store it with the tailcap slightly unscrewed when not in use.
