I ordered a bunch of parts off DealExtreme to build my own lights for the house.
DIY GU10 Kits with Single and Triple Optics
Some XR-E Q5 Stars
GU10 1x3Watt 650-700ma Drivers for 110v
and 3x1Watt 300-320ma Drivers for 110v
The kits #15084 / #15085 come with a heatsink, plastic body with GU10 legs, Optic (either single or triple) and Screws.
I saw others complain that the screws don't cut it but the ones I recieved worked out great. 2 to hold the star to the heatsink. 3 to fasten the optic. 2 to attach the base to the heatsink.
Theres a problem fitting the driver made for GU10 in the plastic base, it won't fit unless some plastic is removed. Once removed there only 1 screw hole left to attach the base to the heatsink. Though it may sound flimsy when you consider the twisting force needed to put a GU10 bulb in the fixture, I haven't felt any cracking or breaks having removed them several times.
The heatsink is adequate when driven at 3watts, but I don't have a sensor to get a true temperature reading. Since the heatsink is chromed my IR therm. is no use. But shooting in at the star I read 115F.
The Triple optic has a center to center spacing of 9.5mm. 3 XR-E can sit in there spaced apart, but I have yet to template it and attempt to drive 3 at 1watt.
I don't believe the 3 Rebel Endor Star will work with that spacing, can anyone confirm???
The Single Optic is great its a smooth diffused spot, no rings. I'd say 30 degrees and very good as a spot out to 5 feet but has sharp shadowing. At 10' it will cover a 4'x4' area with smoother shadowing.
Here are the parts (just one optic per Kit)
Assembled 1x3watt Cree XR-E Q5 GU10 Spotlight
The shadowing under the dart board is a bit much for me
Now I should measure the wattage of the whole fixture.
In the pictures theres still a 50w Halogen in the paper lamp
I've taken that out of the fixture and added another 1x3watt GU10
The second focuses on the floor.
The fixture has 3 socket and for the third I'd like to keep the paper lamp.
I'd like the third to be an open flood inside the paper lamp and maybe use a Red Cree 7090 to add some warmth to the cool hallway lights. Or a 3x1watt RGB, major changes will be needed to the heatsink (or a new one entirely)
Next for a 3x1watt I have a MR11 board with 3 Warm White XR-E on order from Cutter. Lets see how Cutter's shipping compares to the 7 day order->arrival from DealExtreme.
Though I think they have the orders like the MR11 made for them by contracted manufacturer on an individual basis thus adding to the order time. It may not fit into this Kit.
Some XR-E Q5 Stars
