H3 replacement bulbs
Firehose
I am in the process of replacing H3 bulbs on my golf cart.
Do I buy 12v bulbs or 6v bulbs?:thinking:
you must check if the golf cart run at 6V or 12V
I personally don't know.....
Your golf cart may even be 24 Volt the higher the voltage the less losses in the whole system, I can't imagine a golf cart being 6 Volt.
Norm
Norm
you are probably right becouse I have neve saw a golf cart here in italy.....
however if the golf cart run at 24 volts the H3 bulb must be 24V, 12V golf cart--->H3 12V.....
