GreyShark
- Joined
- Dec 21, 2008
- Messages
- 359
I prefer handheld lights for use with a pistol because I feel this setup is a bit more versatile, has a few tactical advantages and my favorite pistols have no rails anyway. I'm always on the lookout for something new or better so I thought this would be a good way to share some ideas and see where it goes.
I prefer a momentary switch to a clicky for this use because I find it's a little easier to use with certain holds and there's no chance of an accidental constant on. My use of the light is intermittent only and if I do have to use it as a search light for some reason twist for constant on is ok. A clicky can be ok too as long as there's a big enough difference between the press required for momentary and the press required for constant.
Size isn't too important and neither is run time though I'm starting to really like the ~100mm battery tube format because of its versatility. I already carry and conceal a large pistol so I can easily handle a slightly larger light.
A good finish is important because the light is likely to get bumped against my handgun when shooting, not to mention other things in the course of its duty. Along those lines it has to be strong enough to take, or give, a good beating. As I said in another thread I have no problem wearing things out so I'm not interested in character marks. I am interested in durability
I'm not sure if I'm sold on grip rings, mostly because I'm not sure if I'm sold on the Surefire/Rogers technique. I generally prefer the Harries technique but not every technique works in every situation so options are nice. Actually this is another reason why I'm coming to like the 3x CR123 configuration, it's long enough that the grip ring doesn't have to interfere with your grip if you're using a different hold.
I am sold on a throw beam with 200 lumens or so. I like being able to put most of the light where I want it even at a distance and one of my practical realities is the need to be able to survey my entire property from any point therein. I also need a tight enough beam to punch through trees and brush. I'm rural, not an urban dweller. If I do need to illuminate a room I can bounce the light off the ceiling as long as its output is enough.
I've found a pocket clip to be very handy. I don't like them on knives but I don't use a flashlight the same way I use a knife so it's not a big deal. I do enjoy the benefits to ease of carry and being able to attach the light to various things to illuminate a work area if needed. Again the 3x CR123 format is generally long enough to keep the clip from interfering with the grip ring. I don't think the C3 looks as nice as the C2 but it sure is practical.
I like a finger loop style lanyard because it allows me to throw the light around to the back of my hand to reload or perform other tasks.
If you use a handheld with your pistol I'd like to hear thoughts and observations from your experience.
