I recently received the "new improved" 0G0D01 version of the Maha MH-C9000, moving up from a Rayovac PS4, which worked flawlessly for what it was. I got the C-9000 mainly to test capacities, and to hopefully get a more full charge out of my batteries. The PS4 had been tested elsewhere to only charge to 79% on a quick charge.
Anyway, I've tried quite a few different sets of batteries at 1000/500 or 1000/1000 charge/discharge rate, and I cannot seem to achieve a tested discharge capacity thats near the actual capacity, even with very good batteries, my charge capacities are only rarely meeting the rated capacities of the batteries, but the discharge is even lower. Even if I bypass the 1 hour rest, when cycling/etc... I still come in 300mah or more under capacity.
When I started using LSD batteries, I began coming within 50-100 mah of rated capacity. Rayovac Hybrids all tested around 1950mah. Most of the other reports on the same batteries, with the same (probably older versions) of the same charger, or the bc-900 were coming out well over 2000mah. Are most batteries, even Sanyo 2500's, 2700's, or Duracell 2650's really that far off? I'm wondering if the new revision is not as accurate as the previous models.
I have a 80mm computer fan stuck temporarily to the vents(it's not cooling the batteries), and hooked to a old r/c wall-wart tricke charger to cool the charger itself down. Maybe this will make a difference.
