I run regular burn-in tests for many of my lights. The Longest Running time is from resistored LED lights, namely Mag 3D with Tektite LPR-3 or Micra-light, 1 5 mm LED light running on a 3.6 V lithium thyonil-chloride AA Cell. They have a tail of light lasting for weeks. Same with SF L1, that on low is running the LED direct drive (10 Ohm resistor) from the CR123, for a minimun of 50 Hrs runtime.
The best lantern time is from a 6 Volt (4 F alkaline cells) with a Tektite LPR-113 (LuxI SE with built-in 8.2 Ohm resistor), hitting two months of runtime (to 10%).
One tea-candle LED light in now on its third month on 2 Alkaline AA cells.
WHat is problematic are 5 watters (third KL4 died) and incandescent running on Li-Ions. I'm testing a "90 lumen" LF bulb in the E2e, and at the 10 hrs. mark it developed some black inside the bulb envelope.
I also have some underpowered incandescent that have hit the 1000 hrs bulb life. A P60 on a single Li-ion lives forever. A G4 12V 10W bulb powered at 8.5 V is above 8.000 hrs mark.
I have had 5 mm LED lights where the LED lived for few hours; on the other hand I have found the longevity of LuxI and LuxIII (driven slightly under specs) to be overwhelming.
An historical note: My longer runtime light from the late '70 was a LED Flasher made with a RED LED and a LM3909. On a single D Cell, it lasted three years.
Regards
Anthony
