It is brighter with high drain cell. My measurement shows it pulls about 1/2 amp more with sony vtc5 compared to olight 3400 mAh protected cells. It isn't a huge difference visually. But if you need all the brightness you can get (that's why we're here in Vinhs forum, right?) panasonic 18650bd would be a good option- at 3200 mah and 10A drain they'll have good runtime and good performance in this light with its medium level demand. I havent checked performance with an ammeter yet. They are flat tops, so you'll need to put a solder blob or magnet on the positive side of the cell as this light requires button top.Awating for mine..do you guys recommend to run it with highdrain or normal 18650 batt.
Cheers TMACK, Did not know that, thats great! More lights need temp based IMO! Vinh said it will run 20mins easy and I guess thats standing still or walking so when rideing a bike it will be able stay on turbo forever (well untill the battery gives out!) but that wont be long at MAX lol! I wont run it on max though most of the time but nice to know I dont have to worry about it. I was thinking more actualy runtime as in how long the cell will last! I guess 45mins on a 3400 as stock dose 900 on a 2600 so 1200 on a 3400 should be about the same! Fine to bump it up for decents and use a lower mode rest of the time with spare cell!I'm not sure on max, but I know it does have a thermal step-down, instead if a timed step-down which is much better. I run mine for hours on a little over medium when I'm sharpening or soldering. I absolutely love the hc90vn. The sd6vn is another great one. Mule , magnetic mounting if you want to stick it to your hood. Pocket clip. Very versatile, but the hc90vn is more powerful and throws further. Sd6vn =indoor Hc90vn = outdoor
Witb velcro, yes as long as you're not a flat biller. The pastic piece the light swivels on is curved. I think it would be great for a hardhat using velcro.I just found out about this recently. Would this convert to a cap light easily?
Lol tmack's the reason I got mine...Tmack, stop it, stop it now, or Ill have to order one soon! Go away!
Do you like it?
Or it's bout time that Zebralight designs an all in one light like this! There are many uses for colored LEDs. So why won't Zebra step up to the game? I'm going to wait for more reviews on this light but I really like it. The only thing that concerns me is that single slide switch durability. And I don't like that you have to go through all color modes backwards to get to the main white light. 2 separate switches would be nice.About time you worked on the Zebralight H600 ;-)
