HDS 2XAA RUNTIME!
thermal guy
ny
I finial got around to doing some run times with my b42 and a 2XAA tube.I have had good times with Duracell pre-charged but wanted to see how it would perform with standard Duracell alkalines.Not sure if i have a freak light but the thing ran for 93 minutes at 42LM.I then stepped it down to .33LM and it has been ruining now for 9 days straight! Holy cow....
That's pretty impressive. Do you plan to run the test a 2nd time to see if you can duplicate the results?
Awesome! Now if Henry would start making some 2xAA tubes for the twisty...:whistle:
Mayo
That's some runtime!
Turbodog showed really bad runtimes when on Level 1 on AA alkalines years ago. Are you sure you didn't miss a drop? NiMH showed really good runtime.
Thats possible like i said i will have to run it again.But even if it did step down it still ran for 90 minutes on high or a level down and now its on it's 9th day at .33! Thats just nuts.
14 days on .33 LM after an hour and a half on high! all on 2 Duracell alkaline? This can't be right:thinking:
