kerneldrop
It's great that HDS is back to pumping out products.
Now if only I could afford one (or justify buying a light I really don't need.)It's great that HDS is back to pumping out products.
Where did you get the smooth bezel on the rotary?
I modified a crenellated bezel.Where did you get the smooth bezel on the rotary?
I'd be interested to know how you did this.I modified a crenellated bezel.
Just a drill and various grit sandpaper, 60-2000, once I got to 1000 and 2000 I wet sand. Used the drill to spin the bezel as fast as you can. I used a small mechanical plug to hold the bezel, just replace the wingnut with a regular nut.I'd be interested to know how you did this.
Thanks for the info. I might try this. I have a few extra bezels lying around.Just a drill and various grit sandpaper, 60-2000, once I got to 1000 and 2000 I wet sand. Used the drill to spin the bezel as fast as you can. I used a small mechanical plug to hold the bezel, just replace the wingnut with a regular nut.
Make sure the bezel is held square, no wobble, if it's off a little it will end up uneven.
Takes all of 5-10 minutes.
I wouldn't. I'd be worried about compressing the springs too much.I received the second of my two ordered HDS rotary lights this week. One CR123 NLT and an 18650 SDR50.
I notice the 18650 ships with an unprotected cell. Any harm in cramming a protected cell in there or is it way too long? I'm nervous to damage the springs
You can but why? The HDS ships with a Japanese made INR battery. It doesn't need a protection circuit. The HDS electronics won't kill it, and an INR is far superior to the ICR or IMR chemistries.I received the second of my two ordered HDS rotary lights this week. One CR123 NLT and an 18650 SDR50.
And I'm over here wondering what the emitter choices will be 😆@Hogokansatsukan I wont clutter up your interest thread, so I'll ask here.
Will the Ti Clicky run have 18350 tubes? I think most buyers would prefer that.
