PoliceScannerMan
Electrical tape.
I'm going to guess that you didn't order it from Henry.I got my 140T today, only six days after ordering. GDP emitter.
No, he supposedly did order it directly from HDS Systems. I asked him in the "when did you order your HDS?" thread.I'm going to guess that you didn't order it from Henry.
............My rotary knob moves vertically ~1 when pushed down. Is that normally? It makes pushing the button feel sloppy.
I believed you. I was under the impression that all of the HDS lights took at least several months to ship, but I guess it's only certain kinds - high CRI and rotary according to Grizzman. Lucky me, I ordered a high CRI rotaryI find it odd y'all still have doubts, but here's a screenshot from my gmail (taken today @ 12:08 PM eastern time, October 15, 2013)
I guarantee you I bought this 140T directly from HDS's website.
I guess that the 200 lumens, rotary and Hi-CRI versions are harder to get.
Anyone in hurry and interested in ordering directly from HDS, should probably concentrate on the 140 clicky (or maybe even on the 170 ?).
The second issue is one I've never noticed with the previous HDS I had, when changing batteries and reconnecting the battery compartment with the head I've noticed a small blue spark. I noticed it because I was swapping out batteries in the dark. Not sure if that's normal.
I saw a spark from the contact wire on one of my ACME Clickies the other day as well. I had never noticed it before, but there seemed to be no issues with it afterward so I assumed it was nothing to be concerned about. :shrug:
My Legacy HiCri would spark and it also had a parasitic drain issue. It would drain a primary in a week of almost no use. Sent it in for repair and I haven't noticed a spark since. Not sure if the two issues were related.
A standard 14mm silicone boot would probably work in a pinch, but it would feel mushy without modification since the internal nib is not flush with the bottom of the boot like the stock boot is; at least the one I have. Also not sure what the OD of the brim of the stock boot is since I didn't remove the retaining ring to measure it.
Mine are all flush buttons, but in the pic above, it looks like the tactical button is "filled in" to activate the same switch that the flush button does. You may be able to fill in a standard replacement button with Dow silicone cement (look for bathtub caulking section at the hardware) to get the proper feel, assuming it fits otherwise.
