ForrestChump
- Joined
- Oct 20, 2014
- Messages
- 3,097
Do these use PWM for lower outputs? Their sit is really vague.
No PWM.
No PWM.
Not exactly 100% accurate. Go to the FAQ http://www.hdssystems.com/Content/LightFaq/ and read the section under the question "What is tint control?" Henry suggests that the light uses some sort of a hybrid between PWM and current control but doesn't clarify further.
Thanks for the thorough explanation
The easiest way to understand what you're missing about PWM is that becomes less detectable as the rate/speed goes higher and makers have come a long way since the days of the L0D in removing its negative effects from our lights of present.I am one of those PWM SUPER SENSITIVE types. There is nothing perceivable in the light output I can detect at any level. If there is some high-bred as you suggested ( I didn't read the link ) I would consider it completely negligible to the point of not mentioning it. Just my opinion.
+1It's worth a mention it's specifically not recommended to use the rotary as a dive light as the seals are not designed for that. It also says while it isn't recommended it is capable provided you set the switch up for the water pressure it will endure keeping the switch engage (EX - setting it for High only ). It also says not to twist the switch underwater. All that said, I would have no reservations taking a Clicky into seawater at snorkling / free-dive depths. If your going deeper than that and must bring an HDS - I would go Clicky all the way.
You could more accurately state that Henry has figured out a rate at which he could use PWM and its positive aspects while relegating concerns over the negatives to some of our older lights.
The mere presence of PWM was a pretty negative issue for most of us here when I first joined CPF and I remember well the conversations of a few years back in which we started seeing some lights and the rate of the PWM explained well enough that we started feeling differently about the issue. It still confuses me a bit between various forms of regulation and how they all affect tint, along with output level, but I don't have the same fear of the existence of PWM in a light (unless its an older one I'm considering buying) that I did a couple years ago before makers started addressing raising the rates of on/off cycles to the point that we could no longer detect the dreaded strobe effect.I think thats fair, it's also above my pay grade on how he does this, it seems you have a better handle on that. I just don't want someone reading "PWM" and think the usual and thus forgo a purchase based on that alone. I would never consider a light that uses PWM except something like the Polytac that can forgo the lower PWM settings. Yet I use an HDS exclusively on all levels without any perceivable ( normal? ) PWM. If it's a non issue for me, I think it would be for 99.9999% of people who really don't care for PWM.
IMHO, HDS does not use PWM.
I love the AlTiN bezel. Does the standard tactical tube (CR123A) come with AlTiN or Nitride bezel?
Here's my new 250 Clicky with 18650 tube (the battery wasn't included).
It came with the AlTiN bezel treatment rather than the black nitride.
Check out the new packaging, a square tube rather than the standard clamshell-type.
I ordered without a clip because I have a spare black standard HDS clip, I just took this picture straight out of the package...
Great looking light! Flat tail cap? Stand nice? Looking forward to my 4000 XP-L nuetral with the 18650 tube.....
Hogo likes to call them elves, I concur. reepans, did you observe any of these elve like creatures in any of your photos?
