emarkd
Another thought - to attach the clip to the bezel, without changing the distance of the reflector to the diode....
You know how people put the clip under the bezel, but it messes with the placement of the reflector?
A few days late, sorry, but we still seem to be on the same topic so I wanted to address these comments. You can already put a clip under your bezel without changing the reflector/emitter relationship. You can put a clip under your bezel without affecting the beam pattern at all. You just put it on top of the reflector, between the reflector and the bezel, instead of between the reflector and the head. I cover all that in my write-up, if you're interested -- http://www.candlepowerforums.com/vb...all-a-Clip-Under-the-Bezel-of-Your-HDS-Rotary
FWIW, and I don't mean to speak out of turn or put words in Henry's mouth, but I don't think Henry's issue with this clip-mounting solution is a functional one. I think he's more concerned about strength/reliability. He designed the bezel to screw down a certain amount for strength, 3 full threads or whatever it is. With the clip in place it screws down less, maybe 2.8 rotations or whatever. This technically makes the bezel connection weaker, and possibly less water resistant. But for me personally, I find the trade-off worth it. These lights are so far over-engineered (in a good way) that I'm comfortable "compromising" mine slightly for this added convenience. And like others have reported, I've been carrying like this a long time, in all sorts of situations, even underwater, without an issue.
But again, this mod can be done without affecting the reflector/emitter geometry at all. And if I'm wrong on Henry's thoughts on this I'd love to be corrected please
