During the past 9 months, I have had 3 headlamps and each failed because of (I think) a problem with switch. I use the headlamps when I run in the morning, usually 4 times a week. I had two Petzl Tikka Pluses and 1 Princeton Eos. After two weeks use with the first Petzl, a white creamy substance appearred behind the lens. With the second Petzl, it took about 4 months before the creamy stuff appeared. After 4 months with the Eos, I noticed that the switch cycled through just two modes. After I changed batteries, the headlamp no longer illuminated. The only thing in common appears to be the switches. Has anyone heard of similar problems?
