nunuboogie
- Joined
- Aug 25, 2008
- Messages
- 2
can anyone recommend a small bright helmet light, run time 1-2 hrs.
Thanks
Thanks
:welcome:can anyone recommend a small bright helmet light, run time 1-2 hrs.
Thanks
:welcome: nunu!
You'll need to be a little more specific so we can help you better. You mean "helmet light" as in caving helmet, climbing, bike, industrial...
There's a ton of lights that can be mounted on helmets but knowing where you'll use it would help us make a better recommendation.
NiteRide MiNewt USB?
For helmet mounting, you'd want the USB Plus, IIRC.
I use the Fenix L2D Q5 and it's sort of OK, but I wish it had more throw and more total output. A lot more. Maybe one of those new Oilight M20 Warrior Premiums is in my future... oh wait
This is basically what I used to have (20w 7degree mr16) but I still find the L2D a better option and less hassle too.12v 20w mr16 halogen lamp ("spot") and a 30watt hour battery pack, 14 nimh cells. Should give you just under an hour of some good light.
Thats what has stopped me, a pity too as it is seems really quite good otherwise.Look at the regulation graphs
That'll soon stop you!
:welcome:Fill a noob in on what you mean?
Hi nunuboogie, :welcome:! Your decision may come down to balancing how much runtime you want vs. weight vs. personal preference. I used to carry around an older Fenix P3D as a back-up / helmet light on my night-time, trail rides. It gave me 3+ hours of light on High... but, it lacked in terms of throw. I then carried a Dereelight CL1H but I found that, after 3 hours of riding, my neck was sore. Carrying smaller lights such as a P2D-Q5 might be lighter and more reasonable but it doesn't quite have the throw or runtimes as a 2-cell light. If you only need an emergency, get-back-to-the-trailhead type of light, then a small 1-cell light might do the trick. If you want something more, then you'll have to get a larger 2-cell light (ie. P3D-Q5, TK11, M20, CL1H) but be prepared for the added weight... it surprised me how much I noticed it during my rides. Hope that helps.Thanks for the info.
The light is wanted for cycling, MTB communting and off road. Already have 2 x lumicycle halogen light for the handle bars, but wanted a spare / back-up light for the helmet. Cheap and small with no wires would be prefered.
Well, you can always pack a second 18650 battery... I still carry a CL1H (3SD pill though) as a back-up and I pack two additional 18650's with me just in case....You will see that when the TK11 is running on 18650 batteries the graph shows that the output diminishes gradually over 2 1/2 hours. Fenix lights usually are very well regulated.
