Hi all,
I have been crusin the forums for a little while now, reading and now i have some questions. Hope you can help.
I got this knockoff surefire (yea i know, but for $35 with batteries...) It takes 2 CR123 lithiums, and has a Lumileds Luxeon (TWAJW 0210609 2606LXHLLW3C is on the back of the star) LED/Star. It worked awesome for a few months, brighted LED flashlight ive ever used, good runtime, no issues. then the last 2 times i used it, for less then 10min at a time it got hot. very hot. I took it apart and the batteries were cool and the heatsink was warm, and i didnt see anything wrong. Then i took it with me for work, thru the airport xray machines twice and when i got home it was not a happy flashlight. fully charged batteries and the LED would be semi-bright for a split second after i click the switch then would only faintly glow. the driver is pretty much 2 1/2 watt resistors (cant see the ohms without cutting wires).
So i assume the LED died for some reason :mecry:, what would be the best way to replace it? i was thinking about a regulated driver as well but i dont think it would fit. how do i determine the optimum running Voltage of the LED, maybe they were over powering it and it died early?
i can take some pics of the assembly tonight if it would help.
Anything else i should try? or test?
thanks all
Jason
thanks all
Jason
