help for optics for LUXEON III led/Lambertian/WHITE
HackoBoy
Hi guys.
run theme because I can not handle alone.
before that I put this LED optics
FRAEN - FHS-HNB1-LL01-H. - LENS, LAMB'N, NARROW BEAM, W / HOLDER.
but I do not like light. Could something else to replace it - to have better lighting.
I noticed that when I drive in fog than the main beam and a second which is scattered light. so I want to make a modification to have only a single beam.
:welcome:
Good job using full part descriptions, that is great.:thumbsup:
Unfortunately, :confused: I'm sorry Hackoboy, I'm not sure what the problem with the beam is. (and the Fraen optic)
those optics are medium at best. Fraen LP and NX05 are much better.
For best results, use IMS reflectors (for Luxeons).
There are 17 mm, 20 mm and 27 mm ones. The larger the model, the smaller the main beam is
http://theledguy.chainreactionweb.com/index.php?cPath=48_50_64
(but dont forget, that Luxeons are only half as bright as actual tech led (Cree XR-E, Seoul P4) when running with the same power.
And the yproduce double the heat
... in short: get Cree XR-E or Seoul P4 instead)
I could not find this site if you can shop and sent me to Bulgaria. Can you help me with that information sent to Bulgaria.
A good european supplier for LEDs is dotlight.de Shipping to bulgaria is 7 euro. I've used the 4degree Carclo optic here and found it pretty good. But have a look round at what else they have available.
