reminds me of something I made awhile ago
Max756 8-DIP set to 3.3V, squeezes out about 3.6V 120ma from a 1.5V, which I had connected to a CREE P4 and mounted everything on top of an aluminum bar where I would then connect via some sort of a tie down to picture frames.
While I bought add an AA holder to both sides it worked so well I had it connected to a homemade "CR123A battery box" where the plug is connected to. So I get to drain both AAs, and CR123As while keeping some light to a family photo:thumbsup:
Lighting done by L4
Off
On
Unfortunately for this particular project I forgot to mod in a switch, so either the battery comes off, or it gets drained. And its been a bit brutal to NiMHs which I forgot I set them in.
While most of the parts I used in this particular project is salvaged... with the exception of the Perf board, DIP holder, Max756, and the CREE P4, I only measured about 60% efficiency, peaking to about 80% at 3V, and quits at 0.7V
the CREE P4 is very efficient on a low current, I have a 2xP4 USB gooseneck light [another homemade] that shares a current or just 150ma but can light up my entire computer from above :thumbsup:
