R.ticle One
- Joined
- Jul 25, 2008
- Messages
- 87
Hello everyone,
After some hiatus from this crazy place, I've returned, still pondering my options for a light. On one hand, I'm still keen on having an emitter swap done. On the other hand, I revisited the Malkoff Devices site and had another look at the surefire dropins - particularly the M30WF.
I shied away from Surefire Malkoff dropins at one point because I thought they could only be used with Surefires using two 123 batteries - to be honest, the exploding light stories scared me away.
Now, I see that this dropin M30WF, the characteristics of which really appeal to me, is meant for use with a Surefire running one battery. Correct me if I'm wrong, but that means no explosion risk, correct?
I'm still a bit confused about configuring a light with the right batteries for this dropin, however.
First, I'd probably choose the Surefire 6P incandescent model as the body - that's a good first step, yes?
My confusion has to do with the batteries; on the Malkoff site, it says the dropin is designed for use with "a single lithium rechargeable cell".
However, a bit lower down, it states: "The runtime is 1 1/4+ hours on one CR123 primary battery. Runtimes on other battery configurations are highly dependant upon the size and capacity of the cell."
Which makes me say "so this means that you're not limited to using a rechargeable single cell?"
Now, which is the case?
In one thread, I see someone say:
"My favorite is my M30WF. Just a damn bright wall of light. The tint,beam,and flexablity are all excellent. I can vary output by the battery type. Want full power use an 18650.Want about 120-130 lumens use 2aa.
Want 60-80 lumens with 4:55 hr runtime use 4/3af cell.For me this is the crowning jewel of the Malkoff line. "
http://www.candlepowerforums.com/vb/showpost.php?p=2871994&postcount=20
In another, I see someone say:
"I agree. I have a M30WF. so far I've ran it on cr123,rcr123,aa,17670,18650,4/3a,4/3af,and 4/5a cell.
Here is the runtime test that I have completed.
aa= 1 eneloop starting voltage 1.498v ending voltage of .940
runtime of 2:31 hrs. 60 to 70 lumens est..
17670= Starting voltage of 4.16 ending voltage of 3.56 runtime of
1:16 hrs. 170 lumen est.
4/3a= Staring voltage of 1.467v ending voltage of .958v runtime of 4:20
hrs. 60 to 70 lumen est
4/3af= starting voltage of 1.49v ending voltage of .973v runtime of 4:55
hrs.60 to 70 lumen est.
I still haven't done the runtime test on cr123 or rcr123. I'm going to do 2 eneloops next."
http://www.candlepowerforums.com/vb/showpost.php?p=2834436&postcount=48
So...what's the deal?
What battery configurations will actually work with an incan 6P body and an M30WF dropin - and preferably without having the body bored out to accept different batteries, if possible? Or should I be looking at different lights for this option?
Thank you muchly!
Thank you muchly!
