help me help my brother
fireluvrandrew
So my brother just got a sig 556, which is basically an ar-15, and he is looking for a weapon light for it, and of course does not want to pay surefire price, and of course its my duty to help him out being a member of cpf:), so you guys help me, only requirements, it has to be able to take the shock of a ar-15 firing, and keep working, so let hte suggestions begin
Is a G2L and Picatinny mounts too much. Because that would be more than enough and wouldn't be too outrageously priced.
Dereelight DBS V2. Thing throws some major light.
I plan on mounting one to my AR...
He bought a SIG 556 and he's concerned about SureFire prices? :shakehead
Seriously, he bought the best gun, now now accessorize it properly with the best weapon light.
Well you can't buy a Surefire Weapon Light after you spent all your money on the weapon itself.
How bout' a Fenix T1 for $75:
Info pasted from https://www.fenix-store.com/product_info.php?cPath=22_85&products_id=386:
Fenix™ T1 Flashlight
The Fenix Tactical series (T) features a powerful, solid, durable, and waterproof design intended for rugged outdoor and military use. It's as solid as a tank. The T1 uses two CR123A batteries and maintains excellent constant brightness with two output modes: General mode, which can last for a whole night and can be used for general illumination, and Turbo mode, which can be used whenever high-powered light is needed – search and rescue, long-range target identification, etc.
Features
• Cree Premium (Q5) 7090 XR-E LED with lifespan of 50,000 hours
• Two modes of output, selected by turning the bezel:
¨ Turbo Mode: Constant 225 Lumens, 1.5 hours
¨ General Mode: Constant 60 Lumens, 10 hours
• Highly efficient focusing head - throws beam over 200 meters
• Textured Reflector for optimum balance and transition between spot and flood
• Digitally regulated output - maintains constant brightness
• Low battery indication system
• Uses two 3V CR123A lithium batteries TWO CR123A INCLUDED
• 136.5mm (Length) x 35mm (Diameter)
• Solid stainless head & durable aircraft-grade aluminum housing
• Premium Type III hard-anodized anti-abrasive finish
• 153 + -- 0.5 gram weight (excluding batteries)
• Waterproof to IPX-8 Standard
• Toughened ultra-clear glass lens with anti-reflective coating
• Tactical tailcap switch with momentary-on function
• Tactical body clip – attaches securely for easy carrying
• Anti-roll, slip-resistant body design
• Able to stand up securely on a flat surface to serve as a candle
• Included accessories: holster, lanyard, two spare o-rings, and a spare rubber switch boot
someone is acquainted with their firearms!
yes i know its ironic, but thats my brother I guess, I dont complain, because i get to shoot it, so Im just trying to help out
