Fallingwater
Long post, sorry, but I want to explain everything right, because this is really puzzling me.
I got these two flashlights from DX.
When they came I first tested them with 3xNiMH AAA, and they had pretty much the same brightness. I was also surprised by the high output.
I tossed the 3xAAA carrier in one of them, replaced it with a 18500 LiIon cell with some padding and used it for about two weeks. I left the other one unused in a drawer along with its carrier and 3 NiMH cells.
Today, in the process of reviewing these flashlights for my website (along with a few others from DX), I looked at the output of the light I've been using and thought "hmm, wasn't this brighter"?
I fished out the NiMH-powered one from the drawer, turned it on, and sure enough it was significantly brighter.
At first I figured the LiIon cell was at fault; I hadn't used the flashlight much, but the cell is quite old (like, five years), and we all know how LiIon cells don't like aging.
But when I swapped the 18500 and the 3AAA carrier around, the situation didn't change much.
I measured the 18500's voltage and it reads 3.9, so it's far from being discharged.
I then started thinking maybe the LEDs were being overdriven so badly they had already degraded, but it seemed unlikely. The light was bright, but not THAT bright.
On a whim, I then swapped the tailcaps around. I don't even know why I did that, because they can obviously have no influence on the output... or so I thought.
With the other tailcap, the LiIon flashlight is suddenly bright again, and the other one is dimmer.
I've checked a few times to see if I'm not just high on Mentos (I eat a lot of them), and it is perfectly repeatable: one of the two tailcaps causes the light to be dimmer.
Puzzled, I then took the multimeter and measured resistance.
The "bright" tailcap has a resistance of about 0.3/0.4 ohm (which, if I understand correctly, is probably caused by imperfect contacts and is functionally equivalent to no resistance at all). The "dim" tailcap's resistance is inconsistent. On one measurement it's about 4 ohm, on another it varies wildly between 3 and 25 ohm, on another it's 8 ohm, and on one it got as high as 100.
It's gone insane.
Question 1: WTF??!
How can a simple switch develop a wildly variable resistance? Do I have tiny goblins in there playing with micro-sized resistors?
I should mention the variable resistance seems to have an effect only on the multimeter's readings. When the cap is on the flashlight the output is dimmer, but it doesn't change.
Question 2: am I right in assuming the "bright" tailcap has no resistance?
I can handle simple cells-motor/light circuits, but when we start talking about resistance and ohms my brain starts to hurt, so I don't know if that 0.4 ohm resistance changes under load or what.
I then measured resistance between the head contacts and the contacts of the LEDs (the back side of the board is exposed), and it reads 0.2 ohm. Measuring the resistance between the screw threads in the head gives the same result, so I'm pretty sure the 0.2 ohms are added by the multimeter and there are no resistors whatsoever in the head.
If that is the case, and if there's no resistance in the "bright" tailcap...
Question 3: how can it be that running on low-internal-resistance rechargeable cells, and from my variable power suppy (set to allow anything to draw as much current as it wants up to the supply's maximum of five amps), the LEDs didn't go into thermal runaway and die a horrible death?
These are the new 20.000mcd LEDs... could they be self-resistored or something?
Please help. I feel like I've broken some fundamental law of physics and disproven years and years of studies.
It's gone insane.
Question 1: WTF??!
