ShineOnYouCrazyDiamond
Just ordered 3 - 10280 Li Ions from Lighthound for my Draco and they are all too short. It looks mainly like the bump on the positive end of the battery is flush with the top as opposed to the original battery which has an extended + terminal bump.
When I close the Draco and tighten it down I can still hear the battery shaking back and forth and now light turning on. I tried putting a tiny piece of metal at the bottom of the battery tube which worked, but even if the light is off the metal piece bounces around and makes contact with the negative terminal and the side of the case while the top of the battery touches the positive terminal and the light flashes on and off - you can imagine what that does to the programming with the way the FluPIC response to <0.8s turn ons.
Anyway - was thinking I could solder a small piece of metal to the copper at the + terminal on the light, but would rather do a solution which fixes the problem on the battery rather than risk holding a soldering iron too long on a $250 light.
Any other thoughts appreciated. Thx.
