HELP!!! surefire C2 mod to multi stage?
Qbreitling
Is there a kit from Malkoff or any other modder to make my Surefire C2 KL3 (first gen, finned head) to a multi stage light? Love my C2, but most of the time the output is overkill for my purpose. I would really like to put in a Flood Led with adjustable brightness.
thanks for the info. great stuff:twothumbs. more amateur questions below:
1) from the installation instruction, it seems like the dual stage switch surgery allow me to keep the original surefire tailcap. Do i need a malkoff tailcap? I would much rather keep the original SF part, unless i misread or misunderstood something.
2)How do you select the stages of light after the mod? light press for low, press harder for max? is the switch click on/off? What happened to the twist on/off feature of the original SF tailcap?
3)can i replace the led lamp of in the KL3 (finned head, first gen) to a Malkoff M60F? is it just a simple dropped in or more complicated?
1 yes for the malkoff and yes for mine.
2 I have no idea how the malkoff works. It looks like a modified twisty. Mine clicks on high then low then off.
3 Way more complicated. The KL3 is it's own encapsulated head. YOu could get a standard c/p/m series head and install any drop-in into that.
No doubt I am a Sure Fire freek.
I have been using a P60 since they first came out mid 1970's
Like you I have found that fairly high lumen flashlights, are many times too much of a good thing.
A "Tactical" flashlight is a great tool...
But, for a "Personal" flash light, I have found that the Sure Fire A2 Aviator, with white LED's is the best choice.
If I could only have one small light the A2 Aviator would be "IT".
For "personal use" I find the LED's on low, to be perfect.
The regulated Incandescent at 50 lumens is an OK Combat light when needed, as well as a good "woods" thrower.
PS. I have used it in the Woods of Texas, Idaho, Montana, Canada, Alaska, and in the Bush of Zimbabwe.
