Thanks guys. I learn to appreciate this thing more every time I read your posts.
Well I carried it today and I didnt expect it to feel smaller and carry better then the already small HDS light but it did. It felt like a large tube of chap stick in my pocket and was sexy as hell with that Diamond etched clip just hanging out my pants. :thumbsup:
As for the light engine it was cake to remove and a small pair of needle nose wrapped in a cloth you just spread them apart to fit in the 2 notches of the LED housing. Just takes a tinny bit of pressure to free it up then back out the rest by hand. Going in is the same with just a ever so slight amount to snug it back in place.
All it took was some wiggling and seating of the reflector from the back side using finger pressure right where the O-ring sits. The O-rings stays put if you leave the head flat on the table and screw the LED housing back in from the back side.
I was freaked out and am a newbie to all this but once I see something apart I can fix just about anything. In the Haiku Wave thread by Don there is a pic of the light all in pieces so it wasnt hard to figure out after that.
The only part I dont get and wont mess with is how the lens and reflector actually come out. I am guessing it must be from the front end because it wont fit if removed from the rear where I was tinkering. My guess is that outer O-ring around the bezel holds it in place some how but I have no more need to fool with it now so my OCD is satisfied and my reflector is damn near perfectly centered. :sssh:
