Newuser01
Okay, folks!
How are everyone!
I'm a newbie as far as led lights moding. (the only thing I've done is push in the (warwand LED) into minimag and it worked!!
Could you guys look at the circuit and the led slug/heatsink and tell me what is the best ways to go about getting more lumens out of this? Also I remember seeing someone mention there is a resistor in the tailcap/switch. I need to figure out if that is true and how can I get rid of that if it will help drive the new emiter!!
I'm guessing that this thing has some sort of boost circuit in it. And considering the optic, which upgrade will be better? I would think SSC, ? Since it is better suited to upgrade lux (same radiation pattern?) as LUX!!
Thanks in advance for all the good ideas to come.
Regards.
PS. I have a cheap solder iron (from Ratshak , about $5 i think I paid for). Do you think I can use that?
How are everyone!
Regards.
Newuser01 said:I've had this light for a bit now, it is pretty good but dim in the age of CREE.....
According to some of the posts here, it has just a tad less output than L1T.
Here is some pictures for you viewing pleasures. Easy dis-assemble without any special tools. Small screw driver (for my eye glass repair kits) help unscrew the retainer and the slug out of the head. Re-assembly is also painless and its still works.
Enjoy.
PS. Thinking about putting a cree in here but thnking about the beam with the collimated lens.
