After a good amount of research and question-asking here, I have decided to build a 64458 on a M@g 4D platform powered by 5 IMR26500 cells.
I've got the host and a length of 1" sched 40 PVC pipe to build a battery holder out of.
Now, I'm getting ready to order the rest of what I need.
Question 1: Can this thing be powered direct drive, or does it need soft start and/or regulation? If direct drive will work, is the KIU switch the way to go?
Question 2: This is a budget build. I know that the FM heads would help me get the most out of this light, but that will likely have to be a "Christmas of next year" upgrade. For now, what's a good reflector/lens to use in the stock head? (I think I want SMO or VLOP; I may frost the top half of the bulb.)
Question 3: I got what appears to be a "naked" host at Home Depot. When I do the spring mod, do I still need to sand down the bottom of the tailcap? Is it "clear anodized?"
Question 4: I'm a newbie; the only other "mod" I've done is overdriving a 6-cell Magnum Star bulb w/ 3 x CR123a (in both a plastic Eveready host and a M*g 2C). What else do I need to know? Is there anything I'm missing that I need to be aware of?
Thanks for your help!
-j
-j
