lostsoul01
- Joined
- Feb 13, 2009
- Messages
- 22
In my home there are these old lights which I can't stand.
The plastic is 8" square. When I moved in, each one had a 100w regular bulb in it, and they were attached to a dimmer. I replaced the dimmer with a switch, put in 26w CFLs, and put new plexiglass in there.
It used to be glass, but over the years became very ugly. The previous owner replaced the glass with plexi, but the regular bulbs melted it.
The issue is that the main room is 20 feet x 24 feet, has dark panelling, and is just so dark even with the CFLs. There are 4 lights, there used to be 5 but they replaced the center one with a fan.
I have thought of an option but don't know if the product exists. I'd like to find a bulb socket extender that is at a right angle, so I can put a bulb that faces down in there. Then I could use a floodlight, or even get a EvoLux LED bulb. It wouldn't be much better looking, but maybe would be brighter. Does such a thing exist?? I can't find one in my searches anywhere.
Other options I've thought of is replacing them with can lights, which I dislike that idea, replacing the plexi with a different type of diffuser, or getting some homemade LED fixtures in there. The last one I worry about the cost (everything x 4 lights) and the fire hazard. But I imagine the fire hazard isn't much less with these sideways CFLs trapped in there.
Any thoughts or suggestions? Thanks in advance!
