testosterone
I use a UV nightly at my job. I work the door to a busy club so Im using it all the time to verify IDs. I was using Streamlight Stylus UVs but for some reason they keep dying on me.
I would like something that will clearly bring out the holograms on state IDs and gov't passports. Something that can be used under bright lights (the Stylus works best when used in the dark) and something with a wider spill so that I dont have to scan it back and forth along the ID other documents I get called on to double check.
I was looking at the Pentagon S2 UV but not sure I want to spend $140 on it if there are other choices. I also thought of ordering just the UV head from Pentagon but remembered I gave away my Pentagon X2 to friend and I dont think that UV head will fit on my SF Z2 body. I was also looking at the Inova X5 UV but not too sure about how well it works. I was also looking on DX at the Ultrafire WF-502B but am skeptical on the quality.
I dont mind spending money on buying the right tool for the job. I appreciate any suggestions.
Thank you.
Thank you.
