HID DIY Mod, Peak Halogen
kramer5150
Palo Alto, CA
That little wal-mart stanley is a total gateway drug!! I love that thing, its so convenient with its low mode LEDs too. So its not just all bout lumen blasting (but for the most part... it really is).
I now have entered DIY HIDs... and oh man what a rush!! Anyone who's dabbled into LED mods, Surefire legos, mag ROPs... owes it to themself to dip into the HID pool. Honestly its MUCH more rewarding. The amount of work is the same but... the rewards are 1000s of lumens and enough lux to throw a beam a mile up in the sky.
Thanks to all the regulars here in this sub-forum, with all your advice I am almost finished with my project.:thumbsup: I just need to add the 12AH cell... 144 Watts:twothumbs
Before the mod:
After mod:
I put the ballast on the outside of the light. It doesn't look as nice but I think this will help keep it cool, and this will help free up space inside for the 12AH SLA cell that will replace the OEM one.
Ignition is controlled by a 20A automotive accessory switch. The middle 3-way switch doesn't do anything, but the bottom switch still activates the 3LED lamp on top. The HID kit is 100% plug & play. So technically I could have just plugged everything into the OEM control panel and that would have worked. But, I wanted to add a fuse between the ballast and B+ for added safety and peace of mind, and I don't really trust the OEM switch.
Heres the charge port. Just a deans plug and some 12AWG, power coming from a hobby charger.
Re: Completely sucked into HIDs!!!
Congratulations! But seriously, it took you four thousand posts to finally see the light? lovecpf
I tink that that ballast actually looks kinda neat!
Nice so far, what light colour und power did you chew?
Is the ballast modded? :whistle:
Daniel
Beamshots, Beamshots, Beamshots!!!!!!!!!!:twothumbs
Very cool, and I also think the ballast looks pretty cool on the outside like that.
Thanks gents.
Its a stock 55W ballast. I am a little hesitant to overclock it after reading how another member poof'd his (same kit from the same www retailer). Color is 5000. Its not as pale white as I was expecting, theres a fair bit of yellow/amber, which is to my liking.
I will try and get some beamshots tonight. Hardest part is shimming the bulb, I am still playing around with that. I currently have the bulb shimmed 9mm deeper into the light. Without the shim its like a mag incan on flood, with the doughnut hole.
Do you have a link to more details of your modified 10kk light. My son is fascinated with light and I wanted to introduce him to what you can do with it thru a father-son build project.
thanks.:twothumbs
I don't have any build up pics, but heres some pics of what I have thus far. Electrically the HID system is in parallel with the OEM circuit switch board on the side wall. That way I retain use of the LED light and 12V lighter socket. I removed the charger circuit though.
The large black thing with the orange wires is the fuse holder. Its an automotive blade fuse.
I made the shim out of 26 gage steel. Cut the steel into stips, in my case 7, 8, 9mm wide debur them thoroughly and coil them up so they form a uniform cylinder. I dont have a pic of it, but the shim drops into the bulb socket and positions the bulb. I have it at 9mm thick now, but I may change that if I can tighten the beam up further.
Heres how I clip the bulb into the socket, two paper clips bent to shape. The 9mm thick shim is pictured.
Its almost pointless to white wall hunt with these, but here's all I have. The room was fully lit with ambient sunlight at the time of this shot. All cam settings set to auto. The room appears dark because the camera is adjusted to the HID output.
Left = ROP-High with KD smooth reflector
Middle = Peak 55W-HID-5000k
Right = Stanley HID, output set to hi.
**EDIT**
One more thing... if your halogen host uses an H4 bulb, make sure you get an HID kit that has a removable shield. Not all H4 HID lamp shields can be removed. This piece is not needed, its used in automotive applications to block light from blinding oncoming traffic. But in our case, we want light to be emitted symmetrically around the bulb.
I just bent the metal tabs and pulled it off.
Hey Kramer-MacGyver-Imahara, you got sucked into HIDs fast. Nice pics of your first HID mod.
How heavy is the 12AH SLA compared to the original cell?
I also like the look of the ballast on the outside. How hot does that ballast enclosure get?
-JB
I'm using this battery ZIPPY Flightmax 5000mAh far more usable energy than a similar sized SLA battery, even though the battery is only 5 Ah I get much longer runtime than a 7 Ah SLA. The best part the battery only weighs 400 Grams, I've cut the total weight of my HID in half.
Norm
-JB
I think the 12AH cell is 2x heavier. The one I am looking at is 9 Lbs. Norms idea would be best though. I could get 2 or 3 and wire them up parallel for 10-15AH. But that would put my total investment at ~$250-300. Total investment with with the 12AH SLA is $160. Ballast remains very cold, just barely warmer than ambient conditions. PM me if you wanted to meet up some time. This is not for the weight conscious EDC crowd... better bulk up for the next San Jose night hike!!
Very nice fabrication work there sir! :twothumbs
Thanks for the info. We'll meet up after I start on a project I've been thinking about since after you mentioned the Pelican external battery set-up...imagine Ghostbusters meets HID. All the weight of the battery cells, ballast etc in an enclosure that can be placed into a fanny pack or backpack tethered to a light-weight handheld host. A night hike big lens HID.
-JB
-JB
I thought about going this route too, for my coleman spotlight. You should be aware that the ballast sends ~25000 Volts to the HID bulb. What that means is you need to take extra precautions if you need to splice, re-terminate and extend the wires between the ballast and bulb. The typical solder + heatshtrink procedures we normally do for 12V setups *may* turn your HID into a stun-gun. Video example here...
http://www.youtube.com/watch?v=IPe-n1MDkUQ
At least my HID kit, only had a couple feet of wire. I would definitely need to splice and extend the wires in such an application.
The typical solder + heatshtrink procedures we normally do for 12V setups will turn your HID into a stun-gun.
Thanks for the heads up. I've played with ballasts to create small Jacob's Ladders with climbing electrical arcs, but I never thought about the arcing issue when putting together an HID project. You probably saved me from a truly shocking experience.
-JB
I thought about going this route too, for my coleman spotlight. You should be aware that the ballast sends ~25000 Volts to the HID bulb. What that means is you need to take extra precautions if you need to splice, re-terminate and extend the wires between the ballast and bulb. The typical solder + heatshtrink procedures we normally do for 12V setups will turn your HID into a stun-gun.
In the beginning, I took great care to buy 30 KV rated, 20 awg, silicone wire for making my high Voltage splices. I soldered them together and bought and used 25 KV rated shrink tube to finish off the soldered splice.
Yesterday, I experimented a bit. I still used the rated wire but simply used a Beldon brand butt connector (crimped with Beldon pliers - so no bare spots in the hard plastic insulation) and then I used 2 layers of conventional shrink tube over the butt connector. While I did not test with touching the splices, I put them together and fired up the ballast. No arcing or starting issues.
