andrewwynn
been wondering about the startup resistance of bulbs.. 12V/.25ohm = 48A.. i think i really like the idea of max current.. might not be necessary since i'm going to have a ramped startup anyhow.. maybe like 40-50 mSec startup.. possibly as much as 100-200 msec.. i picked an FET that can handle full power for short term specifically so i can hold back any amount of current or voltage in a 'soft start' incan solution.. as well as constant loads of up to 7-9W in the case of battery/lamp voltage mismatches of up to several volts (i.e. running a bulb at 12.5V from 4xLIon.. where startup Vbat is as high as 16.8V!)..
The FET i picked is the IRL3716.. 4 mohm resistance! 110 to 200W max power dissipation.. and i plan to heatsink directly to the body of the light so not too worried about the likes of 3.35A x 12.7V (absolute dead short on the load.. full power dissipation on the FET)... unless i made some major oversight the FET looks dead on perfect for this job.. 13mV dropout at 3.35A (1185).. meaning i could see as much as 10.787V get to the bulb! (if i blow off current regulation).
I have the parts all ordered so i can breadboard the driver next week.. should have an operational light or two by next weekend. I will do some 1msec peak readings of voltage and current to see exactly what happens with the 1185 and other bulbs. My goal of course it to get constant output of the max i can push the 1160 in a 7.2V host.. i believe i can push the bulb to at least 800+lumen (unless i got some bum data from my hotwire guru).
The other 'gems' that can be pushed if current and voltage are limited at startup... the 1166.. i actually got that bulb to operate at over 14V, but only by pre-heating it at 10.8... it blew the first time i tried to light it up cold with 14+V (which i expected.. it was a 'tester sample'.. no pain no gain.. RnD)..
I believe that bulb can be run at over 12.5V.. that is only 12% overdrive.. and that is over 900 lumen! (bulb lumen)... i have a host lined up to run it... can't wait to see if i have to dial it back.. even if i have to run the lamp at 800 lumen.. it will be 800.0 lumen from 100% to 0% of battery.. no dimming whatsoever... my least favorite thing about hotwire bulbs.. dimming.
-awr
-awr
