daBear
I have a tri bore Mag 85 which uses 9 LiIon 17500 cells in 3 separate FM holders. It has an AWR HD hotdriver of course with a low resistance KIU socket. My problem is the light will not come on unless you actually click it on then work the tail cap back and forth a couple of turns. Then it will come on and work fine. While warm you can click it on and it comes right up and works perfectly. But take it cold off the shelf and no way will it start without screwing the tailcap back and forth.
I have a copper wire on the tail spring to lower resistance, I have applied liquid gold to every possible joint and the batts are fully charged.
The only thing I can think of is one of the 17500 cells is weak and I am not getting enough amperage at the start. voltage checks out within range of 4.2 =/- .1 with no load for each battery pack. (three)
