How do you assmeble a Kiu Switch?
h2xblive
The link in Kiu's thread with assembly instructions do not work.
I'm trying to install the D-Cell Kiu Switch into my Mag, but because of the aluminum "donut" where the two lamp posts screw in to, the switch installs incorrectly in that it won't go far enough into the Mag.
How is this switch to be installed?
You have to remove the snap ring that sits inside the groove in the body. Just use a screwdriver to pry out one end ahile pushing down at the same time. Once it's started out of the groove, just work your way around and it'll pop out.
Hahaha, I just figured that out...I realized the ring wasn't welded to the inside of the body.
Thanks for your help.
