How do you open these?
slammin
Bury, UK
I want to do the brass ring and resistor mod but honestly i cant get in to it. Can i have any more ideas. Ive tried sticking a razor blade in but there is no gap at all so im just scratching it. ive also tried pushing it out from behind with a cut up coat hanger. is it this hard for everyone to get in to their pointer? Can you tell me how you lot all did it?
/ubbthreads/images/graemlins/dedhorse.gif Cheers, Slammin
Just keep messin with the razor - make sure it's sharp and keep working at it all the way round. It will start to loosen after 5mins or so... /ubbthreads/images/graemlins/grin.gif
/ubbthreads/images/graemlins/blush.gifthanks again lasermodifier youve helped me out yet again with another daft simple problem. Now to have a go at your stage 2 and 3 mods. Probably get some more probs but i might as wel have a go.
Cheers
HI,
I use a small pipe cutter. It has 2 rollers on it. just tighten it,, turn it,, tighten it and turn it till it comes loose. don't cut it off. ha ha ha. this works very easy.
laserbug269
I dont know why you are bothering with a razor, all you need to do is grab it tightly with some pliers and twist and pull until it comes loose.. thats the way i did it, it took only a few minutes.. but i admit it was a pain trying to do.
The razor just stops any scratching of the nice shiny chrome finish... /ubbthreads/images/graemlins/cool.gif
Remember...anything worth waiting for is worth having - in this case an unsratched modified laser pointer. /ubbthreads/images/graemlins/tongue.gif
i had to actually saw into it with a very sharp stanley knife then pull with plyers. but ive done it now. quite scratched but its the power i want more than looks.
thanks everyone
